SD +custom chip+ 24lb injectors = ? will it work?
aar0s
1,015
55
69
Cant seem to find anyone that can tell me. Ive got SD now and was thinking about getting some 24's and a chip later on down the road but the swap to MA would most likely push it further down the road.
can i swap to 24's with a chip for the 24's and stay SD?:shrug:
What do you mean it's getting phased out?
More and more people are opting for tuning for injector sizing with custom chips, which is the proper way to do it.
The method of using MAF's with different sized orifice tubes is typically not a good way to do it. Some people expeirence probs with it. Overall it has worked fine, but this method was developed in the 90's before burning custom chips and software was relatively cheap. It was really the only way to do it other than getting a '93 Cobra computer.
Custom burned chips (preferably during a dyno tune) are the way to go these days
cool, is that something that i would need to go to a shop for or could i mail order a chip for my setup or maybe a hand held programer?
No handhelds available for Foxes...
A custom chip can be done, but you're not likely to find a company that will do it mail order.
This should be done with the car on a dyno, or you can do it yourself on the street.
Look into
tweecer.com
moates.net
When looking at 'availablity' for your car, make sure you know your ecu catch code (found on the ecu).
As far as I know, most SD Mustang applications are now covered, but make sure you verify this before you order.
jason
There used to be two main companies that did mail order. I don't know if any of them are still around. ProM (orig) used to also do them. Regardless, with the Moates chip setup, now anyone can make a custom chip and sell it.
Note that I should also add that anyone includes clueless people that don't really have the slightest clue about EFI! So, buyer beware!
But, in a way, SD without a wild cam or SC is simpler to tune than a MAF system. Many/most non stock MAF setups are a POS and a joke. People also seem to like to do stupid air intake setups. IMHO, I'm surprised that many POS MAF setups run at all!
The problem you'll have with SD is that the ONLY reason you need to go to 24's is because of a cam and/or SC. Otherwise, it's a ricer move that is done because people want to say "I have 24's". MANY people with MAF-based systems do exactly that! And, in reality, their POS setup gets LESS HP than if they got rid of their ricer engine mods.
So... You need at least cam to have the need to go to 24's. You also need heads, intake, and exhaust mods. But, SD uses vacuum to determine load. And, a big cam changes the vacuum/load profile. So, it's the cam that's critical to SD being able to determine load. The heads, intake, exhaust have only minor impacts.
So, depending on the lope/overlap of the cam, SD may not like the cam. If you're going with a bigger cam and sticking with SD, get one that's "SD friendly". That means similar overlap to the stock cam. The more overlap, the less vacuum per load. More cam overlap does means more cylinder filling and more exhaust evacuation. So, in general, more power. However, it also means a significant increase in smog emissions (in case someone has to pass a sniffer test). But, as I said, too much overlap is bad for an SD setup.
I'll add in that IMHO, NEVER EVER even THINK of putting a SC on an SD setup unless you have your own Tweecer/etc and know how to use it. IMHO, it's asking for problems. Yea, people have "done it". IMHO, I doubt that a single setup really runs decently as a street car in the summer/winter/rain/sun/hot/cold/etc.
Last, to get a custom chip, check/ask in the classifieds here and on the corral And, again buyer beware! No, I don't do chips.
That's my two cents. Feel free to disagree or ignore any/all of my comments. :)
Exactly what I was getting at Joe :nice:
Individuals can do this as favors or "business"
Few large companies will jump into the custom mail order tune business, as the risk would be rather large.
There's a couple of weasels out there who will take your $$$, and send you a chip... they don't care (or even know) how your car will perform with that chip...
My advice is to take the car to a dyno shop, or learn to do tune via the J3 yourself.
right now i have a 65mm tb, cobra intake, 1.7's, shortys, o/r H pipe, flows with dumps and a 255 pump.
dyno'd at 224 hp on a dyno jet. with the automatic given 20% loss i was figureing about 260 or so at the crank ( I know that the mustang dynos give a more accurate number but this is what i have to go from). For some reason i thought that the hp limit was 300 for 19 lb injectors and some guys around here have got me interested in NO2.
I was thinking about trying to have tmoss port the cobra and run a 75 or 100 shot with the 24s and a chip. just wanting to make sure that i have enough fuel for a zex or NX kit.
You don't need 24's.
If you go with a Zex wet kit, it taps into your fuel lines and sprays additional fuel into the intake, so you wouldn't need larger injectors for that either.
In fact, i'm running the same combo, and i still have 19's
are you running the zex kit with that combo? how much of a difference did it make?
this is all stuff that im wanting to start maybe next summer, this winter ive got to do some body work and replace the carpet :(
no fun parts for me!
We agree. :)
I honestly have very mixed feelings about custom mail order chips.
Many people don't have a dyno shop or tuner near them that is really experienced with Stangs. Then, there's the problem of getting there, getting an appointment, and so on. So, for those people a simple custom chip is a better solution than going with just a scaled MAF (adj FP for SD).
There are a number of cases where going to 24's makes sense and are needed. *I* suggest that people get the '93 Cobra setup (EEC and MAF - and keep the stock air box). By far, it's the safest way.
But, some people don't want that. And, it's "somewhat safe" going with a high-end PMAS MAF, with the stock air box, and getting a custom chip with the exact MAF map and injectors map put into the chip.
If someone has a cam with a lot of overlap, the simple custom chip can even "kinda" help at idle by setting the idle speed higher.
All of the above is a lot better than what many people do - go with a just a "scaled MAF", and/or C&L, and/or a MAF with a cone filter on the end. Any of those is asking for trouble. Yet, many people do exactly those things and they "are mostly happy".
So, I suggest the 93 Cobra EEC and MAF and 24's. That's a great very cheap option and will get a person "most of the available gain". Or, high-end PMAS, stock air box, and custom chip with MAF map and injectors. That gets a person very close to their max gain.
But, to truly tune a modded engine, there are many variables, and a Mustang Dyno (load bearing dyno run) with data logging are really needed to get that last ~5-10%. I say Mustang Dyno instead of a drive because it's not legal to drive as fast as needed to tune at WOT. And, again, many people don't have qtr mile tracks near them, and/or it may be very inconvenient to get to the track.
Also, with mail-order custom chips, the person ordering the chip often isn't very experienced and/or doesn't have a good ability to diagnose a problem. Also, you get the people that think that a custom chip will make their rough-idling 5.0 all of a sudden idle like a Camry!
Between the scam artists and the people doing the mods that don't even know how to use a simple scan tool, there are a ton of potential problems. I hate seeing people get screwed or scammed. With custom chips, even well meaning and good companies and people get stuck with many headaches. And, there are also mail-order chip people out there that _say_ they'll enter in a custom MAF map, but don't. They also _say_ they do a lot of other things in their chip setup, but they do not.
Something else for people to consider. An engineer makes ~$80K-$120+K/year. That's at least ~$45/hr. In New England, the going rate for a Software or Hardware Engineer is a between $50/hr for a low-level junior engineer, up to $100+/hr for some Principal Engineers.
So, IMHO, doing custom mail-order chips doesn't make much sense for many engineers. For now, the demand for Engineers is still pretty good. That's very different than in 2001-2002 when having an engineering degree was like having the plague when talking to recruiters and HR people. :)
So, before someone gets a mail-order chip, if it's one of those cheaper mail-order chips, they should ask themselves who do you think you're getting the chip from? If a person wants just the basic MAF/injector/idle-speed changes, then they "should" be okay. IMHO, a typical high school student could learn how to do those changes for a custom chip in under two hours. (Learning just the "read the change request specs and then do-this" part of doing a custom chip. Not what it really means.) Then, it would take the mail-order chip seller ~15->30mins to do each new chip (emails, burn, ship, etc). But, if a person is expecting (or promised) more from a custom mail-order chip, then I would say someone isn't being realistic.
For reference:
In the year 2016: The 30 fastest-growing occupations - Boston.com
So, as I said, I have very mixed feelings about mail-order custom chips. I do think they have a place. But, many potential problems.
yes it will work , but swapping over to Mass air is not that expensive and well worth it for idle quality and opens your cam choices up to alot better options
IMHO, the problem with a MAF switch over is that many people MEGA SCREW UP the MAF and intake. The MEGA F**** UP the factory designed air intake setup. They use stupid *ss cone filters. They don't use the stock air box. They use POS MAFs like C&L or older ProMs.
So, they end up going from having an engine and system that worked to some POS setup where they have nothing but problems.
Otherwise, I semi-agree. Go with the 100% stock Cobra 93 Cobra setup (including MAF, air box, MAF, etc). And, be happy. People can get rid of the air silencer, and can go with a solid air intake tube. But, no more mods. They could also go to a 65mm TB. After that, any mod is a risk. And, should likely be accompanied with a custom chip.
Those are my views. Take them or leave them. :)
Seems after reading this post that some of you guys want to make something very simple, into something confusing.
If the car truely needs 24lb injectors, swap to mass air, get the proper pro m or pmas meter and be done with it.
Any other way is more trouble than it's worth.
Using a 93 cobra meter and computer is pointless.
Chips and dyno tunes are expensive some going for $750-$1000, on a HCI car it's just a serious waste of money.
If you bought the right parts, and installed them correctly, the chip really has no use in this mild of an application.
The advantage of using a 93 cobra ecu/maf with 24's is that you basically get a custom tune :nice:
The ecu, MAF, and Injectors are matched, and matched using the proper methods.... not some hit or miss 'calibrated' MAF
BTW - ALL 'calibrated' MAF meters introduce some error into the tune... it isn't a question of IF, it's a question of HOW MUCH.
For this reason, stock Ford parts are desirable when ever possible.
The 93 Cobra setup happens to be a great way to run 24's, without any of the possible side-effects that can come from a 'calibrated' MAF setup.
