BurningRubber
- Dec 6, 2004
- 1,865
- 24
- 58
Thats not accurate at all. On my 04 I had, 4.30 gears, 26 inch tire, 108 is where I hit the factory limiter in fourth. (5 speed car). So you can get well above 100mph with 4.30s. Just don't plan on any real power adders.... maybe a small shot of n2o.
Well, I stand corrected then.
My speedo must be off or something even though it's calibrated... on a 315/35/17 4th ends right around 108-110mph according to my speedometer. I figured that would be around (give or take a few) 100mph with 4.30's.
x2
26" tire, 4.30 gear in 4th gear will top out at 108-109 MPH.
26" tire, 4.10 gear in 4th gear will top out at 114 MPH.
Bill
What is 4th good untill with a 28" tire and the stock limiter? That is what size drag radials I have (they are overkill, but they were free) and I figured I might get 114-115mph out of them, but it looks like I might be in luck in case I run nitrous.
I imagine on a stock type car u won't see much if any gains in the 1/4. Takes on heck of a driver mod to pull either off on street tires.
