94 mustang 331 stroker hp estimate?
jrgoleman
knoxville
im wanting to by a 1994 Mustang gt with a full roller 331 Stroker. Trick Flow aluminum heads and intake,BBK Throttle body, 42# injectors, 73mm Mass air meter, 2.5" flowmaster exhaust, Shorty Headers, Roller rockers, Nice cam not sure of the cam specs? Has a Anderson Motorsport Supercharger. Tweecer Programmer. Wide Band O2 Meter, 3:73 Gears, I want to know the hp 1/4 mile and 0-60 times.
it could be anywhere between 400 RWHP to 650 RWHP all depends on how much boost and the tune, 1/4 mile times should be anywhere between 10.50s to 11.50s depending on driver and traction. The bigger concern should be what bottem end is being used if stock that could be pushing limits with a supercharged 331 stroker?
how much do you think that car is worth it has new paint and excellent interior?
thats a tough one im having a similiar motor built right now, the motor alone can cost 10 grand the rest of the car is personal preference but as for the motor without a compression test to see how fresh the motor is u could be spending alot of money to rebuild. If they let u compression test the motor and take it out and bang thru all the gears u could get a good deal on something like that if its fresh but then if it was why would they be selling it?
its at a car lot they want 8,800 for it it runs pretty good it has small header leek and needs ventalation in one valve cover. do you think the stock t-5 tranny is good for these upgrades and what else do I need to ask him about the motor. etc.
The stock T5 will be the first thing that goes on that car usually a stang like u explained should have atleast a Tremec HD T5 but u never know some times they hang in there pretty good but definitly your weakest link also try to get car compression checked for that money he should let u if it checks ok and looks good like u said buy it
