KYB Shocks and Struts
ThunderHorse
26
Ok so I found a KYB shock and strut package on ebay and I was wondering how well they compare to Tokico or Bilstein shocks and struts. I plan on running either the Ford Racing C springs or an Eibach Pro Kit after winter is over so I figured Id upgrade the shocks and struts as well.
They are great. 4 way adjust front, 8 way rear. The rears adjust with a knob on the side which is way easier than the Tokicos. Bilsteins are great, but I would never buy a non-adjustable shock, personally. You can positively affect handling a lot by fine tuning them.
I got the earlier model shocks (for 80s stangs I think) because they are about 1" shorter and I have a decent drop.
Anyway, I've had them for 5 years. Love em. No issues. Well priced.
Stick with the C spring unless you want to scrape on EVERYTHING.
As far as the shocks/struts, the KYBs are more harsh then the Tokicos but they last a lot longer and work well with lowered setups. I had them on my car for over 60,000 miles and never had a single complaint about them.
If you are willing to spend more money then I'd recomend the Bilstiens.
The GR2s have better valving then the stock shocks/struts but they are setup more for a daily driver. They should be nicer then stock but I don't think you will be happy with them if you want a performance shock. I don't think they are better then the Tokico setup that came on the Bullitts or Mach 1s.
I put the non adjustable KYB's on my 99 and was impressed.
They are definatly a good quality set up, and a bit stiffer(more firm) than stock.
When I go to replace my factory shocks and struts on the 04 I am
going with the KYB adjustables so I can play with the settings.
Ive got 50k on the stockers and they still feel like new........:shrug:
Ive looked at both. The ones I was refering to here are actually the GR2 shocks and struts which are the non adjustables. So they are not much better than stock?
I have them and would not buy again, the rears are destroyed in I would say 20k miles though the fronts seem to be holding up. Im going to try out the tokico blues this go around, I was trying to save some coin by going with these but I guess you get what you pay for deals.
Your Sportlines ate um up, They have an incredably high spring rate, no wonder.
The AGXs will hold up. I had them on my car for a long time with HARD cornering and they are still brand new. Put the rears on my dad's car after my driver got smacked up and he loves them too.
