What are you using...
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
To get that stance :hail2:
I am running 17 x 9's all the way around. I've noticed many others with that size- I'm assuming they're 17 x 9 anyway. What springs and such will let me recreate the following without major rubbing issues lowered or not doesn't matter... you can't tell from the pic but my notch has brand new shocks in the rear and still sags in the back.
Here is the patient awaiting springs
Here is what it should look like
shocks dont have anything to do with ride height.
I found every car is different, and what works for one cars stance may not work the same for another.
It goes farther than which springs...... spring isolaters/no isolaters, Condition/brand of control arms, etc.
Best thing is trial and error until you have the look you want.
maxspeed springs and bbk insulators.. handles REALLY well and ride quality isnt bad at all.. stance is good :drool:
kinda bad pic.. the pics are with the 16's though, i now run R's like yourself and they fill it up and create the same stance as the others
Ooooh oooooh so many set ups.... I'm liking this :D
Okay, I have the stock isolators and I guess (:shrug:) stock springs... the previous owner will be at my house all weekend so I'll ask him (DMAN remember the plan... tell mob's girl I'm really on a business trip ;))
PS: All of your cars look AWESOME and I worship thee :hail2:
Sorry for the old post, but anyone else got some advice? I'm running 17x9's all around. Up front are 245/45/17's I think. I never fixed this but I need to now.
It's looking like Maxspeed springs?
Tanx
The pics of what you wanted are now gone....but here's my stance with HR Race springs....MM adjustable LCA's....and FR a-arms up front. Not sure what else what might have affected my ride height. But tell me and I'll list it.
Oh...the rear has 1/4" spacers.....I removed them from the front and get a little rub on full turn. Mine are 17x9 with 245/45 all the way around. Front probably wouldn't rub if I had slightly skinnier tires on em. :shrug:
Eibach Sporlines. No isloaters in the front. stock isloaters in the rear. stock shocks and sturts and controling arms. 1/4 spacers in the front.
Be careful how you set it up though....with all of my suspension mods and solid motor mounts....my car is not exactly "soft."
I'm just waiting for a body panel to rattle off or a filling to pop out over a bump. So if you're driving it everyday unless you like punishment, don't set it up like mine.
:shrug:
Okay I need some spacers, isolators and springs
if you go with Eibach sportlines dont forget caster camber plates. get the gruneail (sp) motorsports ones. under the sticker on there UPR is engraved and there like 90 bucks. or drill out the rivits losen the top bolts and slide the strut eithee direction to adjust it yourself for the time being like im doing till i have the extra cash, then tighten bolt back down. ( make sure wheel is just off the ground when you do this.)
if you go with Eibach sportlines dont forget caster camber plates. get the gruneail (sp) motorsports ones. under the stick on there UPR is engraves and there like 90 bucks. or drill out the rivits loten the top botls and slide the strust eithe direction to adjust it yourself for the time being like im doing till i have the extra cash, then tighten bolt back down. ( make sure wheel is just off the ground when you do this.)
:scratch:
Yeah Strype....listen to this guy! Whatever he just said. :D
