- Apr 21, 2008
- 10
- 0
- 0
I have a pretty simple setup, just a rebuilt 5.0 the standard boltons with a SCT chip (tuned) and a MSD distributor with a big MAF, I think its 85mm. When i start up the car and drive around it works great, the problem im having is ill be cruising on the highway not getting on it or nothing just cruising and the engine will start to sputter a lot of black smoke will come out of the exhaust it will be powerless and it will die. It will start back up and run great again if i pull the power from the battery for like a minute and reconnect it usually.
It doesn't make any sence to me.
It does have a wire tuck job done in the driver side fender wher i found a wire grounding out a while back and it was killing the car but i fixed that wire, (the wire was a yellow one coming from the starter solenoid).
Any thought at all would be appreciated.
