Spring/Summer Build Plans
ike34
156
12
Waterloo, IA
Installing my AIS Methanol Injection Kit
Upgrading to 39lb cobra injectors (Given to me), I have stock 19lb injectors and a FMU right now
Im going to up my boost to 8-10PSI, either by a bigger crank pulley or a smaller S/C pulley
Probably going to go with a 90mm Lightning MAF, Im unsure though, would the lightning MAF be a good choice or should I go with something else? Im running a 70mm MAF from a 94/95 stang right now.
And of course a tune, I'm unsure where Im going to go, I don't know who is good and close to me, I live in Northeast Iowa. Anybody know any places close to me that are good?
Does it sound like a good plan?
Thanks
Todd
I would make a suggestion to you as I have tried 3 pulley swaps with my sc trim vortech and have found one solution that was worth it. I am currently running around 12-13 lbs and its doing great. When I tried to grab 10 lbs I found the 6 rib setup was slipping. I would suggest calling vortech and getting a complete 8 rib setup with a one piece crank pulley with built in underdrive. Not only will you not have belt slip, you will gain from the underdrive AND its about 5 less pounds less rotating mass on your crank. Its VERY light.
Just my .02 :nice:
