It sounds like you have a similar problem as I did about a year ago. My clutch kinda ratcheted so to speak when I pushed the clutch in. I believe it was because the cable had stretched to a point where the adjuster couldnt tighten up so to speak. I did the adjustment and it was fine. Just pull back on the clutch with your foot (towards you with the car off) untill you get a pop. Then just push it to the floor and you should be just fine.
