I am using Edelbrock Performer 5.0 manifold on '93 standard stroke block & RPM heads #60259. Cam is Compcam XE276HR.
I am having a major problem with oil in the upper manifold. Disconnected all the vacuum/pcv connections and fitted breather hoses from the rocker covers to the air box. Oil still a problem.
I removed upper & checked that no oil sneaking through the blocked off EGR port in top of the lower.
Removed the lower #3821 - and behold there is large amounts of oil on the bottom edge of the intake gasket Felpro 1250 in each port. You can see where the oil is sneaking past the bottom of the gasket.
It appears that the gasket is not sealing along the bottom edge.
So it appears the faces of lower are not sitting flat on the faces of the heads.
How can I measure where and how much gap?
How do I overcome this without pulling engine out and remachining the faces?
Richie
Richie
