Ok, got an education on sound deadening AFTER I bought it.
But for the price the FATMAT holds up well IF you put it in places that don't get too to hot.
Heat:
I do not recommend putting it on roofing as it can get above the limits for the asphalt/rubber adhesion backing. MY car gets hot in the very FRONT of the trans tunnel - NOT a great place for FATMAT.
The other hot area is just one part of the passenger side floor boards. The rest stayed cool enough that I am confident it will be ok. I have to give a lot of credit to Ford and/or accufab for keeping the long tubes and exhaust in seemingly the BEST spots for the floor to remain cool. Mine hugs the trans tunnel in front and really doesn't get close to the flooring at all. Then from the mufflers back, it's got a lot of space between the muffler and rear seating area.
Finally, if I had to do it over again, I would have bought Second Skin "Damplifier" INSTEAD of FATMAT for the front tunnel area and parts of the flooring that get hotter.
This is where FATMAT will fail and eventually break down and no longer be effective because it is not a Butyl backing. It is asphalt mixed with a special rubber compound. BETTER than brown bead by far but I can tell in the front of the tunnel it is already losing its grip when HOT.
Another thing I noticed is that the temps remain real cool while driving and the metal cools down fast!
(roughly 75* weather). In traffic, it will get much hotter toward the front of the trans and I am sure in rush hour 95* (that I never drive it).
After the car is shut off the car cools off fast too - at least the metal floor boards.
Smell:
Only when installing do u smell a little asphalt, NO SMELL AFTER INSTALL even when hot!
Sound:
Dunno, haven't driven it. Using my ear not my decibel meter. My preference so deal with it.
Installation:
A pain in the back not to mention you gotta remove the whole interior. Also must use roller to get out the bubbles.
Bioatch SESSION START-->DO NOT GET ANAL ON ME HERE A COUPLE OF YOU. MY test is basic but close enough. I am not going for a Pulitzer prize dammit! I do not care about a difference of 20-30# of total weight, 2 decibels or 10* so deal with it.
END SESSION
Thinking of sound deadening? Read here:
Sound Deadener Showdown
Is it dangerous to inhale or if it heats up?:
Fatmat on another forum:
"this material is not dangerous and the information that is in that forum is talking about the asphalt that you would find on the road. What he neglects to say is that there are different kinds of asphalt which are made with different ingredients. Fatmat for instance has absolutely no hydrogen sulfide. The asphalt that is used in road construction does give off fumes because it is heated to the point of being in a liquid form which releases those vapors. As I am sure you know fumes and odor are completely different. The FatMat is mainly a rubber mastic with a asphalt mixture which is used for the adhesion. The only reason it has an odor at all is because it comes straight off the press and is sent to you.
During installation if you have sensitive skin it may cause skin irritation, so it is a good idea to wash up after the install, however that is not common
We have had this product tested and as long as it is not eaten but is used for its intended use it has no health effects. "
But for the price the FATMAT holds up well IF you put it in places that don't get too to hot. Heat:
After the car is shut off the car cools off fast too - at least the metal floor boards.Smell:
Sound:
Installation:
on my bbk Longtubes. that are 2 1/2 years old, I do daily drive my car.
Most headers will get rust after a few years tho as they are metal.
