- Apr 24, 2009
- 43
- 0
- 0
I have a 89 5.0. I am doing away with the old stock intake setup... My question is will I run into any problems once completed after installing these parts I'm about to list. Will I need anything else to keep from having an issue with the car running well... I am going to the Edelbrock RPMII intake, 70mm throttle body, C&L 76mm mass air with the tube calibrated for 24# injectors, Ford Racing 24# injectors, and an adjustable fuel pressure regulator... I already have a Holley 190lph fuel pump and full exhaust work. For now Im going to use the stock heads, Im just lookin to pick up a little more power with doing the intake and all that goes with it... Will I need anything else or should I be able to add all these parts without it being too much fuel or too much air?
