I haven't put the seal in yet...I was waiting to take it off the stand for that
I also don't have any close up pictures of the rear main before anyways for reference.
there's something going on with the change over for the 1 pc fuel eccentric to the 2 pc....it's NOT common to have the 1 pc on the 87 engine....The Cloyes Set I puchased doesn't say 87 on their web site, but summit DOES....it's so strange -this overlap of this change at Ford-
I purchased this timing set 3 years ago...why didn't I have a problem then? Why is only the high end sets giving me trouble? I checked a gear at auto zone for a "cheap" set and it matches when I use the 1 pc fuel eccentric "old engines" description.
The cloyes set I have is now is # 9-3135
But really i would take some degreaser to that and maybe wire brush it a lil...but thats me. Make her look Purdy!!! Also Scrape those water holes well!!!! dont want any reason for a leak...Lightly sand or wire wheel if ya need to!!! I like using a good painters scraper. Some kinda anti Seize on the bolt threads going into the holes for the water jacket would help. Also they sell bolt kits....Based on the rusty threads around the water holes i would say those bolts are eroded.
Just wanted to show a picture of where the fuel pump eccentric was located and why it shouldn't make a difference on the crank gear of the timing set.
