- Jul 27, 2008
- 138
- 0
- 0
Instead of High jacking someone’s thread I will attempt to show that a 8" slick and a 10" slick both with the same compound will have the same traction for a given car.
M/T slick
Tread Width: 8.0"
Section Width: 10.0"
Diameter: 22.4"
Circumference: 70.0"
Rim Size: 8.0"
Code: MHR-03
Compound Type: HB-11
M/T slick
Tread Width: 10.0"
Section Width: 11.1"
Diameter: 26.3"
Circumference: 82.0"
Rim Size: 8.0"
Code: MHR-64
Both have a compound of HB-11 That compound tells how sticky the tire is.
All Slick manufacturers have various different compounds for different vehicles, weight and road surface.
Here’s the tricky part.
For simplifying the numbers lets take a 4,000 lb vehicle, a 10 inch wide tire and a 5 inch wide tire. And to make it easy lets say that each tire has a 2" wide footprint (cross section)(what’s on the ground). Both tire compounds are the same.
The 10 inch wide tire has 20 sq. inch of surface area on the ground.
The vehicle weighs 4,000 so that would be 1,000 per tire, the 10 inch wide tire has 50lb per sq. inch on the footprint.
Now the 5in tire. It has 10 sq. inch footprint, same 4,000 lb vehicle except now there is 1,000 lbs on a 10 inch foot print or 100 lbs per sq. in.
10 inch slick has 50lb per sq. inch on the foot print but is twice as wide as the 5 in slick that has 100 lb per sq. in.
The actual number for a 8 vs 10 inch slick are different but the outcome is the same, The 10 will have less weight per sq in than the 8, but it's wider so they become the same.
If compounds are the same and the weight of the vehicle is the same the traction between a 8 and 10 inch slick will be no different.
Ain't math fun.
M/T slick
Tread Width: 8.0"
Diameter: 22.4"
Rim Size: 8.0"
Code: MHR-03
M/T slick
Tread Width: 10.0"
Diameter: 26.3"
Rim Size: 8.0"
Code: MHR-64
Ain't math fun.
opcorn:
