here is a pic of the back side of the rim. called and sent pics to a.m was looking to get the h.r 25mm spacers or whatever other one's would work, but they said the wheel spacers they have will not work, because the rim is flat by the bolt pattern. any suggestions.
thats a good point spray the spacers with primer then flat black. and also to cut the ends down on the studs. but i did alot more research and thats what i found out is to cut the end of the stud so that it will be flush with the spacer. i am really surprised that a rep from a.m did not recommend doing that when i told him the problem i had with these rims. is it a problem in the future to change out the studs if i decide to go without the wheel spacer after i cut them?
