What to do with inner fender?
94Blue302GT
704
Chicago
Ok, i've gotten dimensions previously from this website, and all the corners seem to be lined up pretty well in the engine bay, BUT, the guy did a bit of a hacked up job.
I'll show you the pictures. What do you recommend? Looks like he bought a front inner fender patch panel. I was thinking of buying the rear patch panel and a radiator support piece and putting those in so it's straight.
Help me with suggestions!
pictures are attatched i believe
Hard to tell from the pics but it looks like he welded a piece on top of the upper apron above the shock tower area? It looks like it sticks up higher and may make your hood bulge there? If so I'd figure out how to cut/gring that off and weld a stock size piece in at the same level and fill as needed to get level. That's a common area where water/rust gets trapped in the center of ~5 crimp welds from the factory and a rust bubble hump develops, had to cut/grind mine out (golfball sized hole) and had a filler piece welded in to be flush.
Jon
welds are ok
ill get vin when i get home
im at hospital with a new baby boy at the moment waiting to go home probbly tomorrow
why does vin matter?
car is original 289 and 4 speed but everything else is in need of help. body is fairly straight other than front end.
I thought the legal vin is the one on the dash. So many of these cars have suffered front end damage and needed to have the aprons replaced, I seriously doubt anyone could seriously consider it "the only" legal vin on a 40 year old car.
Dash plate came into effect in 68. Before that the vin is stampped into the inner fender at the left front. There should also be one stampped so the the fender covers it when bolted up on the right side. Although my car did not have one on the right side. I replaced the innerfenders and core support back in 1989-90 been a long freakin time....but there was no additional vin number on the right side.
Easy. 1964, 1965, 1966, and 1967 had no dash VIN. Therefore, the apron VIN is the only legal VIN on the car. The door tag sure doesn't qualify, and it says so right on it.
It's early, and I just had a baby boy, so i just looked really quick before i had to run to work here....
There is no plate with a VIN, but, it appears there is a number stamped into the steel. It is on the top rail, on the back half. It's a little mangled from the guy beating it into place a bit, so if you think that's it, i'll take some good time and rework it.
Between the shock and hood hinge? That establishes the car's bona fides, but that's the hidden VIN. The one you'll need is between the shock and the LH headlight. There is a notch in the fender to expose that one. Without it, you may have a problem with the DMV.
The VIN shown here is a restamp:
There are many early model Mustangs here in Connecticut that I see at shows and cruises with what are obviously replacement inner fenders without a VIN stamped on them - they are just blank. I believe that it is illegal to stamp your own VIN is it not?
By the way, congrats on the baby boy deal :D
If it was me I would do something about the way that's welded, it may be fine structurally but it sure doesn't look right. Cut it up and butt weld it so it looks like the one piece it should be
Depends on local laws. Stamping your own is probably a heck of a lot less illegal than having a car with no VIN at all. Having no VIN can get you impounded real quick.
If you can stamp an aluminum plate, you can stamp the apron where the number belongs.
Absolutely, I just thought a polished aluminum plate would look pretty slick when i'm all done. I probably should just go the legal route and stamp the metal though. There will be a time for bling.... I don't think at this stage it's ready for it.
