Ok could you explain exactly how this was done..
You took your key they cut it and then you went out to the car and without inserting two programmed keys first was able to start it???
The inserting two programmed keys is part of the anti theft of the pats system.. They intended this step to prevent somebody from cutting a key and just sticking it in and driving off with your car..
if walmart is using a machine that bypasses that using a key that can be programmed to the frequency of the original key I think that is extremely irresponsible.
I don't care if people don't go to the dealer to get keys cut.. It pays me .5 to program a key I can live without it. But I don't see how it's possible to bypass this part of pats.
Something is not right there.. I have seen this happen before but it was because the car already had a chipped key stuffed in the column from a hack remote start.
