My Gears, Tire Size, 60' Time ?????
Venom351R
4,548
40
98
MAINE
I currently have 3.73 gears but Im trapping at only 5,000-5,300 in the 1/4 mile. I purchased 4.10 gears but they are not installed (wont be until the spring)I run 26" slicks on 15" weld racing wheels. What I want to know is with 4.10 gears and 26" tires will I need to shift before the 60' mark and if so is that going to reek havoc on my 60' times?
I think trapping at 5300 RPMS is reaking havoc on your 1/4 mile times. There are lots of internet yodas that will tell you your 60' will be miserable unless you run a 2 speed glide. If you're serious about the 1/4 mile, you want to switch to at least 4.10s. I would think, with that combo, you'd want to shift around 6500, and cross around 6800. You might want to look at 4.30s depending on your target. My $0.02.
whats BS:shrug:
I dont think you understand what I meant. My car (w/ 4.10s and a 26" tire) traps 110 at 6,500rpm in 4th gear. If I sprayed the car Id redline 4th before the 1/4 mile, so the only options are to shift to 5th gear:nono: or drop gearing to 3.73/3.55 or add a taller tire.
A nitrous motor is different then a naturally aspirated motor.
Horse power = (trq * RPM) / 5252
With nitrous, you increase horsepower by increasing torque (via the bottle). He doesn't have that option. He can't increase torque so he has to increase RPM. He needs the higher ratio screw to get his RPMs as high as his heads will allow to take advantage of the comparatively narrow power band.
Adam
dude you dont get what Im saying, 4.10s are perfect for what he has now, but once his car is faster (whether its from nos or a stroker or a blower) with the 4.10s he'll hit redline before the 1/4 mile. thats all Im saying.
I'll never do Nitrous, I dont plan on a blower and a stroker is to expensive. Im going to try and hit 11's as is. Drop weight, better suspension and still have a few options for adding a bit more in the power department.
I give up. Keep on telling naturally aspirated people to lower their rear end ratio as they get faster, but put your flame suit on first.
Adam
I'm not sure what you are arguing, but he is right. If RPM is the limiting factor, eventually you are going to have shorten the gear to keep from having to shift to 5th, regardless of whether or not the engine is N/A or nitrous. It's a stock block 351, so you can't spin it too high.
Kurt
