Hi Folks,
I'm gettin' close. Hope to wake the neighbors in the late night/early AM in the next few days. A few last minute dummy questions:
>> Firing order/initial timing specs for 97 and up 5.0/B303 cam?
>> Timing pointer on driver side of engine bolts to the bottom timing cover bolt and to a small boss on the timing cover. What size/kind of bolt/screw into the small boss?
>> What grade/type of bolt/washer for crank pulley to damper?
>> Water pump (cast iron) gasket sealer on pump side or timing cover side or none? Torque spec?
>> Intake gaskets, not sure of brand but have a part number "M-9439-B302", they are shiny black with blue around the ports on one side, dull black on the other side. Which side goes to the head? Any sealer anywhere? What/where to do with the little "D" shaped, asbestos looking gaskets. Heads are GT40-P, intake is Performer RPM. I only want to mount this once!
>> Does this B303 cam need a break in?
Thanks to everyone for all the help.
Gene
Gene
The questions will probably get more hot and heavy the closer I get to completion, so please be patient with me.
Does it actually need the plates? I would think that without them I would develop an annoying exhaust (tick-tick....) leak. By the way, the package DID come with four of the useless end seals
