As the title suggests I've been having some problems with my '95 lately. About every third start, it cranks and cranks but doesn't fire. Usually takes about 3 turns of the key before it kicks over, then usually stalls right after. After this it starts and idles. Under load, the engine cuts out almost like the fuel line is being pinched, most noticeable around 1500-2000rpm. Happens for a split second. It has been stalling at low rpm's, especially when left idling for a few moments. When it stalls, no sputtering, just dies as if I had turned off the ignition. This sounds like a sensor failing...any other ideas? Fuel pump/filter? Car has 174k miles. Thanks for any advice.
