I just started having an issue with a hissing sound. It doesn't occur on cold start up, but when the water temp hits around 180+ I will hear the hissing noise. I've checked the radiator, reserve, and oil. The car is driving fine.
I've tried to look for a vacuum leak but not felt anything or seen anything. I tried spraying some carb spray and the idle did change, but it is hard to determine which line did it or if it was the injector.
My car is a 1965 Mustang with the 5.0 EFI swap so getting behind the intake is a bit of a pain.
Thanks for the responses or ideas.
