Hissing sound around the intake?
Scudly
168
Los Angeles, CA
I just started having an issue with a hissing sound. It doesn't occur on cold start up, but when the water temp hits around 180+ I will hear the hissing noise. I've checked the radiator, reserve, and oil. The car is driving fine.
I've tried to look for a vacuum leak but not felt anything or seen anything. I tried spraying some carb spray and the idle did change, but it is hard to determine which line did it or if it was the injector.
My car is a 1965 Mustang with the 5.0 EFI swap so getting behind the intake is a bit of a pain.
Thanks for the responses or ideas.
nvm i didnt notice earlier where you said the idle changed. definitely a vacuum leak. go tthrough all the lines one at a time. take off the upper and put a new gasket on.
Spray some directly around each injector if you are having trouble tracking it down. This will rule out the seals on the injectors. This was the last place I had thought to check to track down a hissing noise as well. The rubber seals around the injectors were old an hard. Sprayed some throttle body cleaner around a few of the injectors and the idle immediately changed.
if its that new then dont worry about it. just listing all the things I had to do to track down my intake leak. turned out a bolt was missing.
