Value for a used WC T5?
nothing, yet. figure I'll have to relocate the crossmember anyway. or modify it. I'm thinkin' I'm gonna get the worked over keisler t-45 rs 600 trans I was asking about earlier.
Doesnt matter, its still a POS design tranny. The internals arent the weak part, its the housing itself, just like a Gforce T5, those power levels you listed and what a 3550 is rated at and its a direct bolt in, plus there are tons of them on corral, same case and gears as the tko500/600 i believe, but those tranny's feature better locking rings and synchros etc. 3550's go for around 1k with everything, bellhousing, clutch, cross member, shifter etc
hmm. ok. Well, I'm wanting to put about 700-800hp thru it with spray, and these guys are claiming a tko won't shift above 6000 rpm, which I was hoping to do. they say this one's good up to 7000. I don't know man, i've always used automatics, I just enjoy standards and wanted to drive it too. I can tell you now a regular 3550 won't be strong enough. tko, yes. I was just hoping for better than a tko. I don't know.
i hear so much mixed stuff about the tko transmission shifting. i think alot of people aren't setting them up properly honestly.
i know the transmissions will handle more then advertised generally, the 3550 is rated for like 400 ft lb's right? are they safe with 500 rwhp? :shrug:
There is a dude local running a 331 with a 125 shot and has a bone stock 3550 in his car, i think his best time so far is an 11.30. On the bottle his car made 430rwtq. Its been like that for 3 years now so I think it'll be fine.
Numbers seem to vary on the 3550's but its generally around 400-450tq on those. Thats above and beyond what any T45 is going to handle.
And especially if you're looking for 700-800hp on the spray, better be looking at a T56 or a tko600 at least
331 on 125 spray is only making 430 tq? :shrug:
anyway, im sitting at 440/410ish right now with plans for 500/high 400's atleast. i'm not sure if i should spend more for the tko or just get one of the 3550 setups that are more readily available.
decisions decisions..
Yeah his car i believe only made 330rwhp before the sauce, it was just a simple n/a 331.
Unless you're doing 5k clutch dumps on slicks i think you'll be ok with a 3550, it can always be upgraded later
