You going to have to turn up the power to get 12psi with that thing?
man I really would have liked to seen at least a 6061 plenum on there, and good to see you did like me and used the stock rails! The plenum swap alone is huge. but I bet it pulls a hell of alot harder.
When does it go back on the rollers? I'd be interested if you guys can overlap the graphs to show the PI vs the Edelbrock intakes.
How much ground clearance do you have with the downpipe underneath the K member?
You and your brother seem to do good work! I have a question, knock on wood lol. If and when your motor ever goes. What plans and or route will you take on the motor?
If I had to guess, forged shortblock and 20psi.
No welded tubes or axle braces from someone like Che?
Got a video of the 2-step?
And, are you gonna to to Fayetteville on Sunday if the weather holds off? Joe said that he wants to. I'll probably go if you guys do (and assuming the weather holds off), although I doubt I'll run.
