First a little back ground info:
My car is a 25.5 sfi chassis 91 GT, set-up for small block ford with motor plates, built around the NMRA Drag Radial class, well those guys just got way too fast for my pocket. I built 3 nitrous motors that I never even ran, swapped to a F1R Procharger with a 360ci motor that I never ran, then I had a weird change in my life....
I had started building a turbo 93 Cobra street car for a customer, in the end it made over 700RWHP on 9psi had A/C heat and was a blast to drive on the street...drives better then a stock mustang. I realized how much I really missed a nice street car, so I decided I was going to put mine back on the street, cage and all. I couldn'y believe I could build a street car that drove that nice with all the creature comforts and power out the wazoo, at will even 80-mph it will destroy the tires with little effort. It really opened my mind, or Im getting older..lol
I decided to go MODULAR, the more I learn about the modular platform the more I like it. They are the future, being pushrod guys we may not want admit it, but they are. I did a Procharger on a 2011 and made 630HP, do you know how much money it takes to to that do a 5.0??
So here's my basic build:
SUSPENSION/CHASSIS
RNH 25.5 Chassis, mini tub
UPR K-Member no motor mounts
UPR radius rod a arms 1" short
UPR coil over kit, Strange Struts
Flaming River Alum front shaft and rack
Motor Plates for the 4.6
RNH Fully built 8.8 rear, Moser 33 spline axles, gun drilled, star flanged, 5/8" Ti studs (Ill swap these to steel for street use), Lightend Moser Spool, 9" ends.
Team Z upper arms, offset lowers, anti roll bar and wheelie bars
Strange Double Adj coil overs, my own mounts
RNH Parchute Mount
Safecraft Fire System
MOTOR
Alum Teksid 4.6L
Stage II ported SHM B heads 97 Cobra, lots of goodies, Stage II cams (may swap a set of stock 97 Cobra cams I have laying around here at ther shop)
RNH Short Runner 97 Cobra lower intake, RNH custom sheetmetal lid
Stock Cobra forged crank, aftermarket rods and pistons
RNH Dist drive based of crank trigger MSD dist
Wilson 105mm TB
VMP tuning, slot MAF
POWER ADDER
88mm Turbo
RNH Custom Turbo System, completely fabricated in house including manifolds, will be a forward facing system, 3.5" hot side, 4" alum cold side, 5" down pipe
Air to Water Intercooler
Tial 60mm Wastegate
Tial 50mm Blow Off
FUEL SYSTEM
RNH Custom, Fuel Lab pump, -12 feed, -10 return, 160# inj, Versa Fueler inj drive, 12 gal fuel cell, MMR rails.
ELECTRONICS
Stock 97 Cobra harness and computer, RNH tuned with a SCT
Holley Annilator Ignition system, individual cylinder control, Holley coil, Luanch control, crank trigger etc
WHEELS AND TIRES
Billet Spec
15" x 12" rear
15" x 4" front
BFG or MT 325 or 315 Drag Radials
BRAKES
Wilwood, four piston front brakes, 5 lug
Wilwood four piston rear brakes, 5 lug
SKRC manual kit
TRANS
Currently RNH built Powerglide with JW Bell, although Id prefer a manual
Photos and updates to come....I need to get a few things out of the shop before I can truly dig in and my wife is due anyday with our 2nd child, a boy. Looking for an easy 1000hp...
SUSPENSION/CHASSIS
RNH Parchute Mount
MOTOR
Alum Teksid 4.6L
Wilson 105mm TB
POWER ADDER
88mm Turbo
Tial 60mm Wastegate
Tial 50mm Blow Off
FUEL SYSTEM
ELECTRONICS
WHEELS AND TIRES
Billet Spec
15" x 12" rear
15" x 4" front
BRAKES
SKRC manual kit
TRANS
