AEM
bsk116
I have a stock (except previous owner installed a "MARCH" brand ram air intake) 1987 GT vert and would like to replace the current intake with an oil less AEM Brute Force CAI.
My question is will the AEM work with my motor that does NOT have the mass air flow sensor? Or does another manufacture offer an oil less CAI.
I don't know what you're referring to when you talk about an, "oil less CAI" :shrug:
What CAI contains oil?
To answer your question though. The AEM system work just fine as a speed density tuner getting its information from a MAP sensor.
If I were made of money, I'd be running the AEM and speed density too! :nice:
Do you have wideband O2 sensors on each bank? I hear that's the hot ticket for that system.
By "oil less", I'd assume he means a non-K&N style filter?
Looking at their website, it appears that they only make products for mass air cars, so no, they won't work on yours right out of the box. They look like they are an "in the car" style of filter anyway, so they will be essentially worthless as far as adding any power. You'd be better off removing the air silencer, if it is still there, and dropping a K&N filter in the factory box. If you're set on getting an aftermarket cold air, go to summitracing.com and search for one by your vehicle, then take your pick.
From their website:
AEM Intake Systems are designed to produce massive horsepower and torque gains as well as better engine sound when used as a replacement for the factory airbox and air filter.
That right there would make me figure that their product is a smoking pile of monkey doo.
Depends on which one you have. The piggy-back system differs from their stand-alone (I don't remember the specifics).
The one I looked into a couple of years ago was a stand-alone setup and would run either a MAF system --or-- and SD type setup.
You are correct about the oil less filter, poor wording on my behalf.
I did not get the stock intake when I bought the car.
You are also correct that the AEM system is for mass air only. It appears there is a limited selection of kits for the 1978-88 speed density motors. Thanks everybody for your help. I'll keep researching.
Coat your mass air flow sensor with a thin layer of ketchup to aid in airflow across the sensor. Install a methanol injection system but DO NOT run methanol in it. Run straight seafoam. You'll be glad you did. If the o-rings on your fuel injectors are split at all or dryrotted, consider replacing them with small rubber bands. Rather than the AEM, I recommend the hose-fitting cold water injection system from Loews.
You forgot to mention the electric supercharger. :notnice:
