Feedback on manual brake conversion
CarMichael Angelo
8,909
234
Birmingham, al
I get in the car and start out . I ck the brakes and decide to give the pedal a pump. The car only marginally slows...
I come to the stop sign at the top of my street and have to stand on the pedal to bring it to a stop. ( this will never do)
Thinking that the rotors are all rusty from sitting, I decide to drive it a little more and keep testing the brakes. after 5 miles, they still will not stop the car any better. ( It takes a Herculeg to bring it to an aggressive stop, you cannot get it to lock up the tires)
I did all of my homework. I modified the pedal ratio to 6:1. I installed an adjustable proportioning valve, I installed a 10lb residual valve for the rear drum brakes, and I bled every ounce of air out of the lines when I bled the brakes. I have a great firm pedal.
Yet if I had to "panic stop" the car, I'd be in dudes trunk.
So I decide to ck into my Jegs order to see if the M/C that I installed was actually the one that I thought it was supposed to be.
No, it wasn't.
After ordering a M/C w/ a 1.125 bore, and talking w/ Wilwood, I learned that despite all of the other modifications, you cannot generate enough line pressure w/ a M/C bore that big. They recommended a maximum bore diameter of .875 ( that's 7/8" for you math majors).
I send mine back and get what I thought was a 7/8" bore instead.
At .875 w/ the 6:1 pedal ratio you can comfortably generate 700+ lbs of line pressure w/ your leg. The bigger the bore diameter, the less pressure you can generate.
The M/C I have installed is 1.031" .
Now this thing has been installed and bolted on the car full of fluid since November. Credit goes to Jegs, because they are willing to refund my money ( all 79.95) despite that there is no box, instructions and the thing is used.
Unfortunately, the only company that makes a .875 bore diameter M/C is Wilwood. Unfortunately, it is 199.00. Fortunately, that's only 120.00 more after the Jegs credit.:nice:
AHEM!!
#1. Fittings are on the wrong side.
#2. I no longer have the standard stud that the stock pushrod clips onto.
If that thing will fit the holes I have in my firewall I'll try it. ( It is autozone after all, they will take back a non-molested part)
Thanks for the tip.
AHEM!!
Thanks for the tip.
Last time I used one has been some time back, and I made my own lines...don't remember what side they were on. For 35 bucks I figure it's hard to go wrong. Sorry if it wouln't work. :shrug:
Well I'll tell ya. Based on Allens' suggestion, all " stock" replacement master cylinders listed for manual brake applications are .875 bore diameters. If you use a m/c w/ a 1.125 bore ASCAP manual m/c, better plan your stop about a block ahead of where you actually intend to.
Be interested in knowing two things once you get this thing installed Mike:
1. Does the .875 M/C contain enough volume to run the 4 wheel disk
2. Did you end up with an acceptable degree of pedal effort
What brakes did you end up with at each corner?
That is interesting that Willwood said .875'' is the biggest you can go, the 86 SVO master cylinder is 1.125''
I took that as Wildwood saying that the .875" bore was largest recommendation for a manual application.
Unless you have some really large calipers requiring some serious fluid volume.
But i agree..SVO MC for manual brakes is gonna be a hard pedal with "average" size calipers
Right now they are stock disc/drum. For the immediate future that's how it's gonna be. When I figure out how I wanna convert the fronts over to 13" and possibly keep them 4 lug, and scrounge up some T/C rear discs, then the M/C that I'm getting ready to put on it might not be up to that task. But considering that it cost 25.00 w/ it's "lifetime warranty", I'll bite that bullet when I get ready to change the system over.
I ran that M/C that I posted the link for on my '79 drag car... with discs/drums off of an 87 gt and it worked quite well. Not great by today's standards, but in 1989 it was great. you shouldn't have any problems with it. I wouldn't go to the SVO m/c unless the calipers are upgraded as previously mentioned.
