I get in the car and start out . I ck the brakes and decide to give the pedal a pump. The car only marginally slows...
I come to the stop sign at the top of my street and have to stand on the pedal to bring it to a stop. ( this will never do)
Thinking that the rotors are all rusty from sitting, I decide to drive it a little more and keep testing the brakes. after 5 miles, they still will not stop the car any better. ( It takes a Herculeg to bring it to an aggressive stop, you cannot get it to lock up the tires)
I did all of my homework. I modified the pedal ratio to 6:1. I installed an adjustable proportioning valve, I installed a 10lb residual valve for the rear drum brakes, and I bled every ounce of air out of the lines when I bled the brakes. I have a great firm pedal.
Yet if I had to "panic stop" the car, I'd be in dudes trunk.
So I decide to ck into my Jegs order to see if the M/C that I installed was actually the one that I thought it was supposed to be.
No, it wasn't.
After ordering a M/C w/ a 1.125 bore, and talking w/ Wilwood, I learned that despite all of the other modifications, you cannot generate enough line pressure w/ a M/C bore that big. They recommended a maximum bore diameter of .875 ( that's 7/8" for you math majors).
I send mine back and get what I thought was a 7/8" bore instead.
At .875 w/ the 6:1 pedal ratio you can comfortably generate 700+ lbs of line pressure w/ your leg. The bigger the bore diameter, the less pressure you can generate.
The M/C I have installed is 1.031" .
Now this thing has been installed and bolted on the car full of fluid since November. Credit goes to Jegs, because they are willing to refund my money ( all 79.95) despite that there is no box, instructions and the thing is used.
Unfortunately, the only company that makes a .875 bore diameter M/C is Wilwood. Unfortunately, it is 199.00. Fortunately, that's only 120.00 more after the Jegs credit.
No, it wasn't.
