If your cats are plugged, get new cats.
Otherwise, in REALITY, depending on MANY things, you can LOOSE HP. If FACT, if your cats are not clogged, you WILL LOOSE low-end HP.
On SN95s, removing the cats are often a guarantee loss of power across the band.
FWIW, a stock, or NA engine, will LOOSE HP ACROSS ALL OF THE RPM RANGE with no headers or cats (heads open to the atmosphere).
There have been many articles on WHY BACK PRESSURE IS NEEDED IN REAL LIFE for NA engines!
There's a book on Dyno numbers and the 5.0. Instead of wasting your time and money on RICER mods, spend ~$20, learn to read, and do mods that make sense for HP. Also note that many of those tests in the book are NOT done on new cats.
After ~50K-<75K miles, you SHOULD REPLACE THE CATS on a 5.0 because the 5.0 is such a non-clean engine. Still, unless the engine ran like pure **** because of a failure, you're NOT looking at big HP gains compared.
For HP, a new BBK X-pipe with cats is likely
better than a non-cat pipe for any engine that's producing less than ~500HP.
Note: The above is about HP, power across the band,
power under the curve, etc. It's NOT about how it "sounds" verses an exhaust with cats.
Gotta go and adjust my TPS now.
Hmm, 0.9999999v gets me ~60,000HP, gas mileage above 5,000,000,000 MPG, and I run the quarter mile faster than the speed of light!
REALLY!!!!
Just ask at any local RicersRUs meet.
