Tires
That's freakin' huge for the front. One thing you are probably going to run into with a tire that size is "tramlining". It will want to follow every rut on the freeway.
My lightning did that. Wasnt terrible and on a car that isnt daily driven i dont think its much of a issue. I DD'd my lightning too btw, 20 miles a day on the highway, it wasnt that bad.
Here is what you should do, flared fenders are ugly.
http://www.stangnet.com/mustang-forums/7917801-post37.html
Wouldn't the tramlining depend on the type of tread on the tire?
Not in my experience. I've experienced it with two different 'Stangs when I've gone to wider tires on the front. Both had to have the problem corrected by adding caster to the alignment using caster/camber plates. It's not a big deal, you should just be aware that it may be an issue when you're done.
A Lightning is a completely different animal than a Mustang with a totally different steering system. Apples and bananas.
My 91 notch had fox LCA's, 95 spindles and 17x8 245's up front and they rubbed on the K-frame during a full lock.
My 81 notch had fox LCA's, 96-04 spindles and 17x8's with a 245 and they did not rub anything during a full lock.
My 91 GT had fox LCA's 96-04 spindles and 17x9's with 255's and the rim (not the tire) the rim rubb on the K-frame during a full turn. Crazy.
unless you plan on banking the car through NASCAR style turns or taking corners like the batmobile there is no reason to run a front tire that size.
I agree that having all the same size tires is nice, but that is a hella huge tire to stuff under the front and unless you are running the forward offset K and control arms its going to be a PITA to keep those things from tearing themselves apart underneath the fenders. I just purchased a set of 245/45/17 to replace the tires I have up there now. If the 275s would comfortably stretch over the 10.5" wheel in the back I would rotate them back to there and sell off the 315's.
Not forward offset k-member, just the control arms with a stock k-member. That setup they didnt even hang out, but i did have to remove the fender liner.
This car got **** canned a long time ago, but it had the forward offset arms, 95 spindles and bilstein coil overs and they fit great. Like it was meant to be there, rim rubbed a bit on the control arm but nothing bad, and didnt even touch the inner sheet metal at all.
