could it possibly be a weak fuel pump causing it? have you checked fuel pressure?
Thanks, No 11. Fuel pump has been in there for quite a few years, but I have an adjustable regulator and it's set at 40 with vac removed and plugged. I would think a weak pump would make it run bad all the time and not be causing a hard miss.
Know how a V8 will run all-around rough when a cylinder is totally dead? It's not a miss like that... it's a hard miss like the timing is way off. Just sitting in the driveway and idling, you can hear / see / feel it skip a beat every once in a while (no rhyme, reason or fixed tempo to it) and if revved to about 2000 rpm, the engine is like Rrrrrrrrr Rrrrrrrrrrrrrrrr Rrrrrr Rrrrrrrrrrrr Rrrrrrrrrrrrr Rrrrrrrr Rrrrrrrrrrrrrrrrrrrrrrrrrrr Rrr Rrrr Rrrrrrrr Rrrrrrrrrrrrr.... wow, that made me feel stupid doing engine noises on a forum.
Maybe I should do a video.
No, I don't have the OEM. Tore it apart to make a pre-oiler.
