A code P0118 may mean that one or more of the following has happened:
- A bad connection at the sensor
- An open in the ground circuit between the ECT sensor and the PCM
- A short in the voltage feed between the sensor and the PCM
- A bad PCM (less likely)
- A bad temperature sensor (shorted internally)
Possible Solutions
First, if you have access to a scan tool, check the reading of the
coolant sensor. Does it read a logical number? If so, the problem is likely intermittent. Perform a "wiggle" test by wiggling the connector and harness to the sensor while
watching
the reading on the scan tool. Watch for any drop-outs. Drop-outs would indicate a bad connection. If the scan tool reads an illogical temperature, check the resistance of the temperature sensor. If it is out of specs, replace it. If it is in specifications, unplug the sensor and, using a fused jumper wire, jumper the two terminals of the connector together. The temperature reading should now be maxed out to above 250 degrees F. If not, there is likely a problem with the ground circuit or voltage supply.
Check for 5 volts reference voltage at the connector. Also check for ground presence at the connector. If you do not have 5V ref. and/or ground continuity, check for these back at the PCM connector. If you have these at the PCM connector, then repair open or short between the PCM and the sensor. If you do not, remove the offending wire from the PCM and then check for proper voltage at the PCM pin. If it's present now, repair short on the circuit. If it isn't present after removing the wire and checking the pin, replace PCM
NOTE: Usually, P0118 is indicative of a bad temperature sensor, but doesn't rule out these other possibilities. If you're unsure of how to diagnose a PCM, do not attempt.
