Hi,
Didn't the later model distribution blocks have a proportioning valve built into their distribution blocks? Also, as well as, the some of the later model M/Cs having residual valving built-in to them. It seems to me, I re-call reading about this. The valving is necessary to insure no rear wheel lock ups in an emergency. You don't want the "arse end" swapping corners!
All of this aside, I plumbed an adjustable proportioning valve into my rear drums system way back (10 yrs.) when I did my resto. Knowing the front disks were getting 900-1100 PSI, I setup the drums to get about 600-800 PSI. This insures no rear lockups and has served me well over the years. I'm also running a residual valve installed at the rear axle distribution block. I'm running the larger 10 x 2.5" drums. The proportioning valve is that black box just under the M/C.
