I had another thread about a squeaking brake issue where I got a squeak when not braking that went away when I did brake. I thought it was coming from the front but it turned out it was coming from the rear so I had my friend check it out at his work. We put it on the rack and took the wheel off to see if anything was rubbing which it wasn't.
We drove it while on the rack with the wheel off and brake pads out but the rotor held on with a few lug nuts. He noticed the rotor kind of moved around side to side like it was warped almost but he had already turned them when he did the brakes a few weeks back so they should have been fine. Then he noticed that he could pull on the axle and there was play in it when pulling out and pushing it in. Is this normal or is something else going on?
