- Oct 7, 2012
- 33
- 0
- 6
I'm running an AOD right now but it's pretty tired. I recently found a rebuilt FMX with the bell housing and converter for $200. Is it worth it and what is required to swap it over?
AOD converters are expensive. I think a TCI one is about the cheapest decent one.I decided to just pull my AOD and rebuild it, that way I can keep overdrive. I'll probably buy a TCI pro kit to rebuild it with, get a mild converter (2500-2800) and call it a day. Anyone have suggestions for the converter? A street/strip is all I'll need.
When I did mine they were crazy. Mine is a new factory Ford unit. I love it. Steering shaft needs changed too, figure that in.
Well, then you certainly need a loose stall converter.My motor has an aftermarket cam, the few times I've driven it it doesn't do very well until about 2500 rpms or so. Anything under that doesn't produce much power at all.
