I have eibach sportlines, all other components are stock. Of course with the drop, my wheels lean inward at the top and I get really bad premature tire wear. I want to get the cc plates and get this fixed but here is my problem.
I'm running 17x8.5 wheels with 245/40 tires. It seems that when I go to install the cc plates, the top, outside corner of the tire is going to want to rub on the inside of the fender lip. I could go to a narrower tire, but I'm afrai it will look bad on the wheel.
I really like the stance of the car as it is now but it seems I might have to get different springs to raise it a bit. Any of you guys have a similar issue? The springs were already on the car when I bought it. I'm thinking the previous owner didn't really think this thru.
However, as soon as it generates traction, the body rolls, and then what happens? If you have 1.5 degrees of camber, but 2 degrees of body roll, what do you have? half a degree of positive camber, and now the tire is actually pointing outward, onto the outside edge of the tire. Furthermore, there's a concept called "camber gain". That's where the tire gains more negative camber the more the suspension is compressed, according to its "camber curve". But in a strut suspension like these, camber gains at a decreasing rate. Put simply, when you lower the front end of a strut suspension like these, and you don't relocate any of the suspension pivot points, you set it up to lose camber relative to body roll.
