SOLD 92 mustang coupe roller with shortblock
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
http://imgur.com/a/xAnqy
1992 Ford Mustang LX Coupe
Original Florida Car.
ABSOLUTELY RUST FREE
Was originally green,
painted Ford Lightning Red
Grey/ Black LX interior
Perfect Headliner
Interior in near perfect shape
All glass intact
All Interior Intact
Most of interior plastic has been painted black and ready to be put back in#
Suspension
UPR coil over conversion
#Comp engineering 3 way adj rears
Lakewood 90/10 fronts
QA1 12”#150lb springs front
QA1 CC plates
single adjustable uppers
double adjustable lowers
Heim joints to body
strangle axles
8.8 rear end
c clip eliminators
5 lug conversion, extended studs in rear
Moroso Trick Rear Springs
Eibach Air Bag
Weld Prostars 15x10s 6.5 BS with 275/60/15 BFGs
Jegs 15x3.5s with 155 BFGs
Ford 4:10 rear gear
Trick flow Diff Cover
V8 brake conversion
# # Engine
70's 351w 9.5 Block
Balanced and 0 decked
Bored .060 Over
3.850”#rpm Crankshaftstock
style rods with upgraded fasteners Speedpro Flat Top Hypereutectic Pistons w/ Dual Reliefs
Canton 7 quart pan
Pro products Single Plane Intake
Holley 750 Carb
Mac 1 3/4 Longtubes
Compcams xe284H cam
1”#Aluminum Carb Spacer
Various gaskets
Moroso waterpump drive conversion
Moroso Rear Master Kill Switch
Carb Cap
Battery Relocation to Trunk
gauge set (water, oil, a/f and tach) stock C5 transmission and custom driveshaft
3 core aluminum radiator
Catch Can
1-wire 130amp Alt
Full Mallory Ignition System
Full carbed fuel system
New clear headlights
Car has no hood, would need cowl for the Windsor anyways
no windshield wiper assembly, but the original setup will come with.
May be forgetting a few parts
Heads, valve covers pictured are sold
Will answer all questions and should have any pictures you may need
Located in southern Indiana
$3,000 firm. Think that's a great deal, really need the car to go to a new home quickly
