Installing urethane sway bar bushings
89lxsport50
550
Franklin Tennessee
I'm getting ready to install some urethane front sway bar and end link bushings on my '02 GT. Should I support the car on jack stands, or should I use ramps? The Maximum Motorsports installation instructions say to tighten the end link nuts when the car is on the ground to avoid preloading the bar. I wonder if I could just put the car up on ramps for the install and tighten the end links on the ramps?
did you do the end links, bushings on the frame or, all of them? going to doing the same thing to mine this week.
I did all of them. I did the main bar bushings one at a time first. Then I took all of the nuts off the end links, and pulled them out. I just replaced the actual bushings and re-used the factory hardware. I read somewhere you can wrap teflon tape around the bar where the bushings go to keep them from squeaking. Between that and the supplied grease, I hope to remain squeak free.
