Engine New Aluminum Heads
65-Fstbk
316
26
49
Vancouver, B.C. Canada
Ok well good or bad I took the plunge and bought a set of the revised ProComp aluminum heads for my build. They are the new versions and are machined and assembled in the US with good quality components. Have seen some not so friendly comments on the ProComps but my thinking is that they will run just fine. I will definately let you all know my honest impressions of these heads. If I wasted my $$ I will let you know.
The heads have arrived. Took awhile but they had to build them so all seems good out of the box. I checked the spring diameter and they are 1.46 with damper as advertised. Everything looks good as of now. I need a few more components before building the engine though. Water pump, fuel pump (mech), intake (going to order a Weiand Stealth), distributor, starter and carb.
Friend had some on a 67 he bought with a 347 stroker...worst heads ive ever dealt with..hardly any miles on motor and within a short time started losing compression. .went to the engine shop..guides were trashed as were most of the seats too..power output didn't feel that good either..though he was running an out of the box eddy carb and out of the box msd dizzy with no tuning...
Sent from my SPH-L710 using Tapatalk 2
I'm hoping that's not the case. These heads are from Skip White. They use better quality components when assembling the heads which are suitable for a hydraulic roller cam. Hopefully it makes a difference. The heads actually look quite nice and the short side radius even looks pretty good. Like I said, my gut tells me they will run just fine. We shall see.
