Titanium Retainers
85rkyboby
923
96
39
South ATL
Hey guys,
I am looking to order some of the Trick Flow TW 11R's and I see that for an extra $100 you can get the option of Titanium Retainers. I did a search where I found people talking about them, but nothing stating when you should be running them. I'm just trying to figure out if it's worth spending the extra $100 for them. Are they for only high rev applications or is it more to do with strengthening the valvetrain? Are they worth it on a street application or strictly drag? Just some info on the subject would be great guys.
Thanks,
Garrick A.R.
Save your money. I doubt that on a street engine you would see a benefit. If you are going to spin at a much higher rpm, then the reduced weight of the titanium retainer could be a plus. But when titanium retainers are used, valve spring pressures, valve weight, rocker arm choice and pushrod selection all come into play not to mention camshaft selection. That is why conical valve springs have gained popularity. It is all about controlling mass and preventing valve bounce/spring oscillation ect when spinning a bunch of rpm. It is also why overhead cam engines have a superior ability to spin at a much higher rpm than pushrod engines can. Not to mention controlling cam timing events ect.
Reactions: 85rkyboby
Thanks, guys. I will keep looking at it. The car will see some strip time. All the above "mods" will be taken into consideration. Spring pressures, valve weight, rocker arm selection, etc.
i guess i should add to my "just saves weight" it saves weight on the valve spring. run titanium everything in the nitrous car and titanium everything minus the exhaust valves which are iconel. it allows the spring to do a better job controlling the valves at high RPM
Thanks for the extra words. I will be running nitrous, not sure how much yet. I think I will spend the extra $50(per head) for them. $100 isn't much compared to all the other parts cost.
yea we turn some crazy RPM so we need everything we can get to help the springs. with the nitrous cam being just short of an inch of lift we need some crazy springs to begin with
@srtthis Haha holy crap! What's your spring seat pressure?! Will the titanium retainers be helpful if I'm running alot of nitrous and not revving to high(below 6500)? I'm still working out the valvetrain setup for this motor, but I figure if it's a internal balanced motor. Mine as well give it a little more than 6500.
I would confer with a good cam grinder regarding this. Really, the spring pressures, rpm and cam profile are going to determine what you need. I would figure out that stuff first, and then see if it is needed. I money isn't a problem, then go for it. It won't harm anything. Just remember, if the springs on the head won't work for your cam, an you have to buy new springs, you may end up needing different retainers, and havig to buy twice. This is why I recommend figuring out the entire combo first.
Joe
Joe
Thanks Joe,
I'm actually going to be getting my cam from Woody @fordstrokers. I will contact him about it when I receive my DIY short block. I was just trying to get an idea of when they are needed and the pros/cons of them. Thanks guys.
Reactions: A5literMan
