Why Does My Car Not Idle Higher When Cold?
5point0stang88
205
15
29
Car immediately dies, have to give it gas for a few seconds, idle really low like 500 RPM.
I have issue bypass, egr made to stay open, idle at 750 when warm mostly. Stalls in shift, and at stop.
Replaced act, and ect sensors. Fill mod list below.
_____________
Crane Cams 1.72 roller rockers
Gt40p heads
Tfs1 cam
Hardened longer length pushrods
Crane beehive springs
Gt40 intake
Mac 1-5/8 long tubes
Mac Prochamber
Spintech Super Pro Streets Race exhaust dumped
Energy suspension tranny and engine mounts
ARP block to mount bolts
Comp cam double chain roller and sprocket
ARP head bolt and stud
Flowkooler water pump and ARP bolts
Ford racing gasket kit
MSD 90 degree spark cable kit J&M upper and lower control arms
Underdrive pulley kit
Bypass smog
Ford idle air bypass plate
Electric fan
3 row all aluminum radiator
Ron Francis fan controller
Sunpro 5in tach w/ shift light
Hotchkis CC plates
BBK Powerplus 70 mm throttle body and egr spacer
70 mm MAF conversion
130 amp alternator
PA Performance alternator wiring
New clutch
New oil pump and shaft
Rebuilt t5
Weld in sub frame connectors
160 degree thermostat
3:73 greats not installed
You have the EGR permanently open? Why?
Also, you should be able to ditch the idle bypass plate.
Code 95 is related to the MAF conversion. Looks like the wire that taps into the fuel pump relay was not run. That leads me to ask, did you install the wires to tap into the VSS? That could be part of the stalling issue.
COde 67....make sure you hold the clutch down completely though the entire test
Code 34 is a dead EGR
COde 41 and 91 are lean codes in both cylinders. If you have the EGR stuck open, this would be the cause. you need the EGR to be CLOSED.
Fix the code 41/91 , close the EGR and remove the idle plate. Perform the proper idle reset procedure and set base idle and the car should run much better.
Reactions: jrichker
I didn't do the conversion myself, previous owner did. How can I check?
I plan to close the egr tomorrow. It was open cause it causes me to stall when idle fluctuate. It yo yos killing the air source causing me to stall
I'll do keo with jumper on clutch switch like I did running codes
Problem solved by rebuilding 3 burned spark wires (burned off the headers)
And changed fuel filter (clogged)
**And allowing the right amount of air in the throttle body via the IAB bypass plate. I was currently choking it unknowingly compensating for the issues above throwing off the tune.
Now runs powerful, unrestricted, doesn't stall immediately after start up.
Clogged Fuel pump prime:
View: http://youtu.be/wpCalTPi5dU
Fuel filter changed:
View: http://youtu.be/sxtxB_JiJCc
