Expired 1989 Notch
A46thedoctor
1989 mustang coupe. original 5.0 5 speed. pretty rare with not one option. manual windows manual locks and no a/c! canada spec car with 180km speedo. 119,000km so about 80,000 miles This is the lightest mustang set up! It is very clean with no rust. The paint in good shape. 1993 saleen style wheels, SA10 style hood vents. I had planned to install saleen ground effects and paint it black but its got to go, I have no room. The side moldings have been removed and i planned to leave off after paint but i do have door ones if u wanted to put them back on. The interior is pretty clean. 306 motor with forged pistons and h beam rods, mexican 302 block, ported trick flow heads, edelbrock intake, 30lb injectors, 70 mm t body. zex 150hp nitrous kit never sprayed, needs nitrous button hooked up. rear mounted battery, t5z trans, spec 3 clutch, adjustable billet clutch quadrant, canton 7 quart oil pan, alumium drive shaft, drive shaft loop, 1 3/4 long tube headers, 2.5 h pipe and flow masters dumped, auburn diff and 31 spline moser axles, 4.10 gears. moser drag shocks, upper and lower control arms, autometer gauges, b@m billet ripper shifter, msd ignition and msd billet distributor. Easy 400 horsepower, Smokes my corvette. It has cerwin vega 6x9s and door speakers and a double din touch screen radio. I have two corvettes and am out of room. $5500 takes call or text 586 524 3043 Located near Detroit
more pics
