Top End Upgrade??
Fresh 306 Never been started EVER
• 306cid (302 +.030) Windsor shortblock, 28oz balance
• Approx.. 9:1 compression
• '87 302 roller block single piece real seal using early crank
• Keith Black Hypo-18 forged pistons KB707
• Romac 28oz harmonic dampner, elastomer, steel/with steel hub, 3&4 bolt pulley pattern
• Sealed Power moly rings
• Cloyes True-Roller timing chain p/n 9-9135
• Milodon 190,000psi rod bolts p/n 82390
• Melling Hi-volume oil pump p/n M86HV
• Canton 7qt street oil pan p/n 15-610
• AFR 165 64cc Aluminum cylinder heads p/n 1400
• Holley 650cfm double pumper carburetor p/n 0-4777C
• Holley mechanical fuel pump p/n 12-289-11
• Edelbrock Performer RPM Air-gap p/n 7521
• Harland Sharp roller rocker arms 1.6 ratio p/n 4003
• Erson hardened pushrods pn/ E917251
• Crane PowerMax hydraulic flat tappet camshaft & lifters p/n H272-2
• Felpro performance head gaskets p/n 10111
• ARP stainless 12pt fasteners p/n 554-9501
• ARP head studs
• Summit cast aluminum tall valve covers, plain p/n SUM-G3322
• Billet specialties aluminum oil breather p/n 20120
• New early style timing cover with timing pointer
• Milodon high volume aluminum water pump, early style p/n 16230
• Chrome O-ring type thermostat housing p/n M8592C302
• Chrome alternator bracket, early style
• Ford Motorsports billet aluminum pulleys: crank, alt. waterpump p/n M8509C
• Summit rolling engine cradle p/n SUM-G1051
hmmmmmmmmmmm
who built it
never started
9:1 compression - very low- how did he come by that.
28oz balanced in a roller block- you'll need a matching flywheel
crane cam with low lift and rpm range
http://www.summitracing.com/parts/crn-443941/overview/make/ford
RPM Range: 1,800 to 5,400 rpm; Duration @ .050" lift: 216/228 (int/exh); Valve lift: .484"/.512" (int/exh); Good low end torque, smooth idle, daily driving, towing, mildly modified.;
AFR decent heads but the 64CC will lower your compression more. what springs on the heads
Not a fan of high volume oil pumps on most stockish motors. No reason for them other than to pump more oil out of the pan faster. If you drain back holes can't handle it then you accomplish nothing.
High Volume Oil Pump
Overall, not my choice in parts- dont know why the non roller cam, crank, balancer,
Certainly not getting you 450 hp
How much does he want for it.
and as stated before i would replace the cam with trickflow stage 1. as for compression.... idk how he came by it. i wanna get alist of things i need to ask this guy. because my list of questions is. 1. whats lowest u will take right now.. 2. whats your address.
As far as the Pistons that must be a very old pn because I can't find any hard specs on them besides some posts where guys said they used them and it's a low comp flat top piston
I would never buy a motor without seeing it run or taking it apart. Unless I can see all the parts or he has receipts, I assume it is stock internals and would price it as such. You have no clue how this was assembled or with what parts. It sounds like a bunch of parts thrown together.
Rather than chasing unicorns, why not build what you want the first time and be done with it, knowing it is built right.
Reactions: billbosc
ESP If spending the money to do it right isn't an issue ! I have done this a few times 3 to be exact . The first motor I bought lasted a month and broke the crank . I paid 1500 for it
Yea I gave up on it. He seemed almost not interested? Idk. Anyway. Just gonna do a head gasket kit.. Probably should just order some heads since im going in anyway. Thinking what ones would be best? Latemodel has the edelbrock and sve and trickflow and afr. blah blah blah. you all know im sure lol.
TFS TW . Fel pro 9333pt1 head gaskets . Change the timing chain while your in there too . And a decent intake manifold being that it is off as well
So no more rebuilding the bottomend? You're scatter braining on us again...
Did you get your trouble codes worked out? They'll follow you with the new top end.
Lol. Definitely scattered out. I agree. It's hard though when I have so many options lol. And of course I am in a hurry to have it going. @addermk2 at this point I completely understand.. As for trouble codes the tps code/ is only one I can't fix. Meter was reading
.86 volts so it's in range. Goin to get a new one. Buuuuut....... Another option I have is there is a 302 5.0 on local craogslist out of a explorer for 600. So again I have another option. I could simply get this motor, swap out mine, put this one in and have the car at least in shape to tune and run. Maybe slow my hurried butt down and can rebuild my motor from bottom up knowing exactly what has been done to it and who has done what. Anyway. Yea I get it. I'm all over the place. You guys give me options and ideas and those spin off into other things and I get scattered. Apologies if offended. Not intended. I just want it to be correct but I also get in a rush. I jump on here to get an experienced opinion or two and end up apparently pissing people off lol
Sent from my iPhone using Tapatalk
But again I get it. Gotta be hard to read some of this stuff over and over and back forth when u have done this before and just simply wish you could reach out and ring my neck and tell at me.
