You don't have to spend a couple grand to do it, you just have to wire in the outputs to the ECU. Ive had MS2 and i currently have the holley and there is no comparison for the two, the holley is much easier to use, the learning feature on the fuel map works much better and you get rid of the old junk engine harness with the holley stuff. I know you can build a harness for the MS2 but not for $400 bucks.
The shocks on the hatch door to access the ecu is just over the top! I mean everything is over the top but this takes the cake, well done.... let me know pick up my jaw and move on
KC Pro tuning and wiring Holley EFI - Grain Valley, Missouri - Race Cars, Automotive Parts & Accessories | Facebook
Hes got 4 fox dashes all ready to go for the screen.
Absolutely just figured if you wanted something right meow .... Lol it popped up so just wanted to shareHaha. Thanks Nick. I realized after I got everything together that I could have mounted the bottom of the struts more towards the front of the car so they have more leverage on the lid to lift it quicker. It does hold fine though, but needed 30lb struts. The idea of welding inside the car now is not something I'm interested in doing.
Nice to know he offers them. They look like the blank Florida 5.0 dashes that he did the modifications on.
sorry Scott, despite my audio experience, most of that is confined to residential.@madmike1157, I know you have audio equipment experience so I'm going to ask you for your opinion. What are the typical causes for accessory pop through the speakers when turning on lights and other high current accessories? I finished up my audio system install, adjusted the gain on the amplifiers, and started playing some music. Everything seems to work fine until I turn on my parking lights and headlights. I get an audible pop. It's faint, but it's still there.
My two dash speakers are not fed by the amplifier. They are fed directly for the head unit. The other 4 speakers are fed by an amp along with the subwoofer fed from a second amp.
The RCA cables are not ran parallel to any power sources. Amplifier power and grounds come directly off the battery. I've read that the amp turn on lead from the head unit could cause some issues, and some recommend to use that lead to activate a relay to turn the amps on. I've also read that some say to run the ground and power to the head unit directly from the amplifier so everything is seeing the same reference.
I think the pop is only coming from the amplified speakers. I need to disconnect the amps to find out for sure though.
