I know you're wondering what I've been doing. I know that you've been laying awake at night, losing sleep over your concern that I may have encountered some monumental obstacle that has stopped me dead in my tracks. I know you're saying to yourself "I wish Mike wasn't so far away, I'd go there and help."
If only any of that junk was true.
First lets talk about the center piece. That stupid little center piece is a weeks worth of messing around, for a less than awesome end result.
When you last saw the thing it was flat, and green. The first thing that needed to be done was create some fins. Since I couldn't get the size I wanted to use in aluminum, I opted for steel instead. Considering that the fins will be glued on, the difference in metals wont matter. So I got two pieces of 1/2" wide bar, and two pieces of 1/4" wide stock and cut and glued them onto the base.
That took two days.
The reason being that stuff slides all over the place. Trying to clamp it in place is tenuous because it moves when it's clamped. it literally takes about 30 minutes just to clamp two pieces, which is what I did. I wanted the outside pieces to serve as a reference when it came to mounting the inner bars.
When that was all dry, I cleaned it all up, sanded the "fins", and sealed them with clear primer. Once that was dry, I clear coated the fins. (they are steel after all).
When that junk was dry, I masked off the fins and sprayed the entire thing in wrinkle black.
The only thing left to do to it is come up with a clear cover for the letters. Either I'll place a thin piece of lexan behind the letters, or I'll use a polyester filler similar to what they use to make the "stained glass" kits you see in craft stores, and fill the letters w/ clear poly.
I moved onto lighting the thing.
I want the letters to serve as a back up light, and have the running lights shine through when the lights are on. The center piece is very shallow. (like 1/2" deep) so there really is no room for any conventional light system. Earlier last week I bought some LED strip lights that you can cut and daisy chain to try and solve that problem.
Originally, the plan was to just stack the strips on top of one another in alternating courses. When I got the stuff at the house, and illuminated them, that idea fell through the cracks. The LEDs are too far apart. What you end up with is not what I was hoping for. Besides,you can see the damn things through the letters even when they aren't on.
Look.
The stuff I bought allowed me to cut it into 3 equal lengths. So, that means I have three courses of red, and white alternately. Since you can see them through the letters, I deciided to try and indirectly mount them. (they are attached to the back of the center piece). That only allowed for one row of white, and one row of red on top and the same on the bottom of the letters. Since I had the two extra strips, I figured I'd mount one strip each to help out the indirect lighting.
Again, that didn't work. I prefer the indirect approach.
red,
and white.
Now, this might get better if I paint the area behind the center piece in a silver, and that would act as a reflector. At the same time, I'm concerned that you'll see that silver background during the day.
So the jury's still out on what to do there.
But, I'm jumping myself here.....I haven't said anything about the wiring.
And there is plenty to talk about.
The only thing left to do with the wiring was tie in the headlights, Turnsignals, Marker lights, (of course the back up lights) and the rear TS, and tails. Additionally the Horn, although wired didn't honk.
Yesterday, I was working on trying to get the LED tails wired up and working. I had already bench checked them, so I knew that they worked.
But in my car,...that was proving to be a different story.
I had nothing. No tails, No brakes, No TS,....I didn't have jack back there.
I checked the head light switch, and all of the wires that went to the four corners of the car were hot at the switch. But at the other end,....dead.
Last night,...I download a 78 Fairmont specific wiring schematic. ( I had used a 79 Mustang wiring schematic when I wired the car, I was concerned that I had done soemthing wrong with a possible color change between the two years)
The first thing I notice was the horn. The fairmont shows a dark blue wire as it's horn wire. I had a dark blue wire alright, but mine wasn't hooked to nothing. I got out my test light and grounded one end of it. I wanted to see if that blue wire had voltage on it.
It didn't.
But,..when I hold the test light against the blue wire, and honk the horn?.......
FIAAAMMMMM!!!!!!. By God, I now have a horn!( I'm using a German horn in the car, my horn honk sound like a BMW).
But that's all I got.
I jury rig up a socket w/ a 1157 bulb and hook it to the head light wires. I got head lights.
The harness is now completely bundled, and tied into place. It's almost impossible to trace the wires coming out of the column. I start cutting off wire ties, I remove the column surround, I remove the lower part of the dash trim. I manage to undo about an hours worth of structure in 5 minutes. I start tracing wires.
Every thing looks right.
I call Ron Francis. I tell him my deal.
"You cannot ck a Turn signal circuit with only one bulb hooked up, You need to complete at least one side first" Dude tells me.
"Oh,....Ok that makes sense" I reply. "But what about the running lights?, I got nothing there, and it shouldn't matter how many lights I'm trying to check."
"Have You checked your grounds? nothing will work if it's not grounded properly." He tells me.
"that's the one thing I'm pretty confident about,.I was pretty methodical when it came to scraping the metal, and making sure I got the grounds all tight". I assure the guy.
I go back down to the garage and take the 1157 socket that I had temporarily wired up as a head light, and wired it up as a turn signal for the front left. I went back to the rear, and rechecked the wires to the LED control panel. I take the wire In had as a temp ground off, and move it to one of the ground points I'm using for the engine.
I turn the Key,....pull the lever down,.....and...
[video=youtube;qp-Evu3F3yI]
View: https://www.youtube.com/watch?v=qp-Evu3F3yI
[/video]
There wasn't one thing wrong with the way I had wired the car, excepting that I didn't have a left front TS circuit completed, and I neglected to ground the horn. And of course it helps to have a complete side hooked up w/ AN ACTUAL TRUE GROUND if you truly want junk to work.
So at the end of the day, I got tails. I got turn signals, I got a back up light (albeit a really dim one) and I got a really loud kraut horn. (I honk it just to piss off #2 son whose bedroom is immediately on the opposite side of the garage wall).
Now I gotta put all the dash wires back together, and restore it back to the way it was 24 hours earlier. In the grand scheme of things,.....Happily.
