Now if you look at the post where I said we about had the hood done, that was around 10PM, so, maybe a couple, six or seven hours. But, granted, it was way better than what I thought it was going to be after all your towel throwing. I was even under the impression coming out that I might not even paint it though. You do better work than you were thinking. I'm just sayin that you might be as anal as I am.
The party? I did. Even without smoking a doobie with the hippy fella.
I do think the water problem could be traced to the dirty inlet air filter. The compressor was having to run non stop, increasing the heat more than comes from just compressing air (which is considerable). The humidity in Alabama is pretty stifling in the first place, then increasing the temp of the air I was spraying wasn't allowing the water in the air to condense and be trapped by your water trap. It would finally cool running through that fifty foot hose and slowly build up enough to spit once in awhile. As is the case with both of us, the little sht causes pita problems. Bright side, you can just pick up a new filter while you're getting that switch!:D
The last point. Good picture Mike. I really did have fun. I need to admit I bought and took 1200mg's of ibuprofen at the airport, my back seems to be aching for some reason. We worked hard this weekend. If your hippy friend would just show up again, I think I might take a smoke break!:chin
I have some left over Celebrex from shoulder surgery...
Sent from my iPhone using Tapatalk
Reactions: Davedacarpainter
Lol, that's fine. Ibuprofen are doing the trick. How'd your surgery go?
It was painful for he first 2 nights. The shoulder was pretty tight but after my first physical rehab session it started to loosen up quite a bit. I have full range of motion back. I think I'm ahead of schedule. Shoulder felt good enough to work on the mustang. Got the door panels off anyways gotta replace the door lock actuators
Right on man, I'm glad to hear you're doing well.
Reactions: 92NOTCH01
How is that thumb of yours anyhow? I'm going to screw things up for Mike, but he has a pretty high opinion of you.
It's somewhat functional but not for things that matter, if that makes any sense. Doctor says 1 year until "normal". The skin is now fully healed, but I can't feel sh*t.
Hey Mike, when you get a chance, post a picture of that heavy duty bourbon you have. I want to buy a bottle, I just need to see if it's out of my league financially.
Uhh, let me say this about that Dave....
Don't buy that stuff just yet.
Bookers Small batch....52.99
Do not.. seek the treasure!!!
The Count of Monte Cristo - the newer version
Wait,....you have thousands of great movies to choose from,....No, scratch that,....... TENS OF THOUSANDS of movies to choose from,......and What movie is your #1 of all time movie again?
The Count of Monte Crisco?
Isn't that a movie about shortening?
Reactions: dr. Dan W.
