Running Rich?
If you have 8 wires on the engine harness, you are in better shape. However, you need to locate the correct o2 harness for a manual trans. The jumper can be repinned easily, so don't pass up a good deal on a v8 o2 harness.
Sent from my iPhone using Tapatalk
Mine is also 2/88, and I have the 8 wire engine harness, and looped o2 harness. Interesting how yours doesn't.
Off topic, but my final vin numbers are 212800. I wonder how far apart our cars are
Mine is 216478. Surprise the jump is that high. It's also odd that mine had the 5 wire loop and yours didn't... at least I know now what needs to be done with it. Thanks again for all the help!
Adding that loop will clear your code 67 and allow you to proceed with dumping engine running codes.
Doesn't solve all your problems, but gets you one step closer.
Ha!...very true statement. At least thanks to you and others on here have helped me build the list of issues so I can prioritize. The nice thing is that all the items on the list are easy and affordable :). Looking forward to getting it running better AND knowing things are done correctly.
If you are crafty enough, you can probably add the jumper to the harness you already have.
It all depends on the level of "correctness" you want here.
Best - factory o2 harness wity correct pin
2nd best - repinned factory harness
Perfectly acceptable - modify your harness with a jumper
Ok method - jumper between two wires on engine harness
Hack - cut and splice the two wires
After you get this done, you need to check for voltage on pin 47 on the EEC. You want to do this because you run the risk of frying the EEC. Pull the computer out, set up a multimeter to test pin 47 to ground. Have someone crank engine over. No voltage, good to go. If you have voltage, your pin is wrong and needs to move.
If you am search "mustang o2 harness differences" there are a few good threads. It's not a complicated topic, but you need to pay attention or it can be an expensive mistake
Reactions: a91what
I can definitely add the jumper. I thought about that last night. At least adding it would buy time until I can find the correct harness at a good price.
I have been poking around to find which wires I should jump. Do you know off the top of your head, or know of a thread that would contain that information?
Never mind I found it:
88-90 AOD: jumper from pin 1 bottom row to pin 2 bottom row (as shown in the first picture)
88-90 5 speed: jumper from pin 1 top row to pin 1 bottom row (as shown in the third picture, left connector)
The bad part of the post is that all the pics are gone so I'll have to figure out which side is pin 1.
It's pretty easy actually. It's an 8 pin connector ,and you have 5 wires so 3 open spots. 3 pins in one row, and 2 pins in the other.
basically you add the pin to the 4th spot in the row of 3, and then jump it to the pin directly above it.
You don't touch the other 5 wires. You just add a jumper vertically down at the end.
I wanted to close the loop on this thread just in case someone comes across this thread looking for answers. It has taken several months(lack of time to work on the car), but I FINALLY have made progress on this car. I haven't been able to pull the key on codes since I owned the car. After doing a lot of digging, and re-tracing the previous owners modifications, I found that he did not do the MAF conversion correctly. He forgot to move the tan/red and green/black wires on the EEC. I also added the missing jumper wire on the o2 harness(details outlined above). Once I moved the wires on the EEC, I was able to get the key on codes with no problem. Ends up the code showed that I had a bad coolant temperature sensor, which was causing the car to die and not start after getting to normal driving temp. I have also read that a bad coolant temp sensor will cause the car to run rich. I replaced the sensor and the car no longer dies once at operating temp. It also appears to have resolved the running rich issue as well. Thanks for the help all!
Reactions: Mustang5L5
