Tdc Confusion
sen2two
I've been lubing and pulling it all morning
5 Year Member
Jul 18, 2013
396
58
59
I am just trying to make sure I'm doing it right since there's a whole lot of misinformation out on the internet about doing this correctly. I do not have any fancy tools to find TDC and I am setting the Lash on newly installed roller rockers.
If I'm doing this correct, both valves on cylinder 1 are closed, air pushes out of the spark plug hole, and my pointer on the balancer should be a zero?
Thats correct. When the air rushes it may not point to exactly zero on the balancer. I usually then roll it forward or backward to sit directly on zero. Never had an issue this way. Hope that helps.
Here's another fool proof easy way to make sure a particular lifter is on base of cam and ready for adjustment.
Rotate the crank until a pushrod is all the way up (fully open). At this point, the opposite lifter for that same cylinder is on the base of the cam and ready for adjustment.
Before you rotate again, look around because another one somewhere on the engine is also in position probably. Rotate the engine and continue.
I tag each rocker with a piece of blue tape to mark as done and proceed until all are done.
Simple and cheap method.
TDC location process courtesy of Michael Yount
If you're trying to find ACTUAL tdc for cam installation/degreeing, follow the steps below:
Positive stop – obtain an old spark plug for the Ford engine – most of us have at least one laying around. Put it in your vice, and with a tool of destruction you deem appropriate – cut off the ground tip and bust up the ceramic around the center electrode. Keep pounding to get the ceramic and center electrode removed so you’ve got a good ¾” or so of hollow space inside what used to be the ‘business’ end of the spark plug. If you happen to break the ceramic on the other end of the spark plug, don’t worry about it. Once you’ve got a nice hollow space in the tip of the plug, take a 5/16” tap, and cut threads inside that end of the plug. I found that diameter to go right in without any drilling required. Once you’ve cut threads, screw in a 5/16" bolt about 1.5” to 2” long. Then take your hack saw and cut the head off the bolt. Wouldn’t hurt to take your file/grinder and dress up the freshly cut surface so no sharp edges or shrapnel enter the combustion chamber. Also clean up the threads on the plug so that it easily screws into and out of the plug hole.
Determining TDC – remove the passenger side valve cover. Rotate the engine (socket on crank bolt) until the #1 piston is down the cylinder on the intake stroke. Unscrew the spark plug in that cylinder, and replace it with the positive stop you just made. Only screw the positive stop in hand tight. Install your cam degree wheel and pointer (no easy task in some cases as harmonic balancer and other accessories will have to be removed). You may want to remove all spark plugs at this point because it will make it easier to smoothly turn the engine over in small increments. GENTLY rotate the engine clockwise until the piston comes to rest against the stop. Note the degree wheel reading. GENTLY rotate the engine in the opposite direction until the piston comes to rest against the stop. Note the degree wheel reading. TDC is exactly half way between these readings. Calculate where that position is on the degree wheel, remove the piston stop from the cylinder, and rotate the engine to TDC as you calculated it.
Reactions: Davedacarpainter
