Scrub Radius/tramlining/etc...
sen2two
I've been lubing and pulling it all morning
5 Year Member
Jul 18, 2013
396
58
59
From what I have read here and else where, the scrub radius of these cars is a contributing factor to the Foxbody having tramlining issues. But the issue with that is, it's highly likely that the guy doing the alignment on the rack has 0 knowledge of this... I have paid for way to many alignments to only be half way happy. The only way I have gotten my car to stop tramlining is ride on skinny Prostars up front! Which I like anyways...
But... I have somewhat grown tired of having either draglites or Prostars on my Fox. For the short while I ran 03 Cobra Wheels, I enjoyed it. No worrying about folding them over if I turned to quickly. Or denting them in a slight pot hole. And no one having a tire on hand if you happen to flatten a skinny tire.
So, now I'm planning to go back to a "normal" style rim giving this is my daily. How could one truly fix the Foxbody steering issues with wider front tires? (255ish)
I have a 20:1 manual rack, Maximum Motorsport steering shaft, Steeda Bump Steer Kit, Solid Rack bushings, Coilovers and BBK Caster Camber Plates. I feel that's enough that I shouldn't have to worry about steering issues when set up correctly no matter my choice of rim and tire.
Nature of the beast dude.
Everything about a wider, more stickier tire is just begging to follow the longitudinal grooves in the road surface. Put more rubber in contact w/ the road, make it more sticky, and give it a responsive, short sidewall, and you have all the necessary ingredients for the effect you call tramlining.
The only ways to decrease that is a narrower tire w/ a higher sidewall that acts as a "buffer" to maximize sidewall deflection and absorb some of the road abnormalities instead of reacting directly to them.
There's gotta be a way though. My 03GT with 245 suffered no ill effects no matter what tire I had up front. I could take my hand off the wheel and it tracked straight.
My daily driver has 255s and it's stable.
I realize a fox is a different, ancient beast, but there's gotta be one thing that will keep it in check. I'm kinda hoping my 03-04 cobra steering rack swap helps the issue. I have 245s on my fox
Sent from my iPhone using Tapatalk
I have 2 other cars with no steering issues
1995 3000gt - 275 wide front tires
1973 Mazda Rx2 - 255 wide front tires
My friend has 295 front tires on his vette...
This is a Foxbody issue. Lets put our head together and solve it.
I believe I can solve it with negative camber. But I AM NOT a fan of this.
I run a 245/45/17 up front with upr bumpsteer kit,MM cc plates&coilovers,stock rack/k member etc. I had the car aligned to MM street specs(called them) and it completely solved my issues. 255's won't fit on mine anyway.
Care to share those specs?
RX2 ... youve got my attention ! post some pics please. Sincerely a car guy
The paint job was like this when I got it. I'm trying to get everything else done before I attack that...
Thread officially derailed, lol...
That's awesome ! There was a few at one of the last shows I went to up in the Bronx here . I'm into everything car wise
Old topic and is not rocket science. :) (maybe it is but has been previously solved many times)
Reactions: A5literMan
