Help!!! 94 Sn95 Rear End
. I have a 94 gt with a 8.8 rear end . When I got the car it had the rear end whine noise . Now when turning it makes a loud pop and sometimes a grinding noise. I took the diff cover off and it has a set of 3:73s. All the gears look great! Would it be a pinion bearing or axle bearing ??? There was no metal shavings and the gear oil was clean
My neighbor had a popping sound in his pickup, it was just the beer can I tied to his driveshaft
Grab a friend and head to a parking lot, drive slowly around in a figuare eight while your friend listens on the passenger side and you on the drivers side for the offending noise, also watch for excessive side movement in the rear axel.
Reactions: PerformanceRed94GT
