Explain a lot of pressure, 16lbs is not a lot of pressure, you should be able to squish the upper hose with the cap on and system hot, engine running. Start by pulling you t-stat and test it in a pot of water on the stove, a meat temp gauge will work, just don't tell your significant other what your doing, some frown on using kitchen tools around automotive parts.
If your t-stat checks out have your radiator checked out.
This is contingent on other parts of your cooling system operating correctly
I've replaced the thermostat 3 times already. The one in the car now is a fail safe. I would think it should be fine.
The radiator is an EBay 3 row aluminum radiator with two electric fans. Could it be possible that this radiator isn't sufficient?
